2004 clk convertible bose amp location?
Old Dec 23, 2015 | 09:39 PM
irokdastar's Avatar
2004 CLK 500
Hello everyone so I pulled the carpet on the left side (driver side ) and I can not find the amplifier. Does anyone know where to find it ? Thank you
Old Dec 23, 2015 | 11:21 PM
Nealgobert's Avatar
Rentals
It's a fair distance back in parallel fashion on its side. I don't recall but I believe it's difficult to see- all that's visible is the leading edge containing the connections. You are in the correct area as it is on the drivers side accessed from the trunk tucked into the rear quarter, so don't give up and keep looking and you will find it. I left mine in place when upgrading the system and just unplugged the harness as I felt there was no need to remove it.
Old Dec 24, 2015 | 01:28 AM
irokdastar's Avatar
2004 CLK 500
Thank you. Is it in front of the rear wheel ?
Old Dec 26, 2015 | 12:52 AM
Nealgobert's Avatar
Rentals
No, should be above it.
Old Dec 26, 2015 | 12:47 PM
irokdastar's Avatar
2004 CLK 500
thank you . i tried to do it yesterday but since it was ranning i couldnt do much . I am trying to figure out how to remove the trunk panel that has the convetible panel shock . do i need to remove the panel as well?
