CLK 500 air box dis-assembly question?
CLK 500, 2013 C300 Sport
Is it possible to open the center part of the air box on these cars? I know each side has its own filter that is accessible but for the life of me cant find anything on opening the center part of it.. Thanks!!
I have this bad habit of getting bored and taking things apart is the honest answer to that! HA! I actually wanted to get in there to see if there was anymore baffling or other obstructions I could remove. I know the air box mod has been beat to death on these forums between it making a difference or not. I had a CLK 430 that i gutted the air box on and the ole' butt dyno noticed a difference without a doubt. Iv'e honestly been really disappointed in the 500 compared to the 430. That 430 sounded way gnarlier and had much better throttle response with the same mods as I now have on my 500. Not to mention the 430 had 225k on it when I got it to my 500's 69k. Theres no issue with the 500 as it runs oh so well and gives me 25-26 mpg on the highway.... the fun factor is just way down now.
05 CLK55 AMG (1 of 247) Cubanitsilber designo series
I've read here that you can remove the two philips screws on the underside of the airbox and the two halves slide to come apart. Haven't tried it yet myself.
Reopening this thread, hopefully, someone could shed some light on this in 2023
Have you managed to find a solution for opening it? I proceeded to remove both screws and found it super difficult in opening it. Specifically, on the intake section where the MAF sensor connects with the airbox, there is a noticeable groove where the top and bottom halves meet. My initial attempt involved using a plastic trim remover to detach it, but it appears to be firmly stuck. I am concerned that applying any additional force may result in damaging the plastic retaining clips mentioned earlier in the thread. I would greatly appreciate any advice or suggestions."
