Restraint malfunction after replacing seat belt retractor
I don't believe anything is broken on the plug. There is a switch on the plug that I have tried in both positions with the same results. I can try reseating the plug, but wanted to try here first in case this needs to be reprogrammed.
I was also going to try the original again to see if the error clears then.
2004 CLK500
I would opt for a new sensor which is about $300. Easy enough to install yourself.
I initially thought I would need to do this, but have tested that the sensor on the retractor itself is throwing a bad code.
- I was able to switch between my "defective seat belt" retractor and "defective sensor" retractor and the SRS error goes away.
- I have taken my car to the dealer twice and had all my errors cleared twice for other unrelated issues and the SRS error is still there.
My driver side seat belt is stuck and i am looking to buy a used one. I am not able to find one on ebay, can any one suggest where to locate one.
Car details
2003 CLK320 w209
Front left driver side seat belt retractor
