Driver's Rear Window goes down only 6 inches
'08 CLK350, '05 E320, '98 E300
The drivers rear window will only lower 6" when either operating it with the switch or in attempting to put the top down. This window not lowering, of course, stalls the top in mid-position.
What is going on here?
azbob213
2008 CLK350 Cabriolet, 79K
2005 E320, 180K
1998 E300 turbo diesel, 280K
azbob213
2005 E320, 180K
MBworld Guru
It's either in need of re-synchronization, or you have a broken regulator mechanism. First, try to re-sync it: Pull fuse #32 (dash fuse panel) for a few minutes to reset the left rear door controller (yes, I know there is no "left rear door" but it's the same circuit as on the W203 sedan that powers the rear window controller). After that, try lowering the window halfway, then raise it fully and continue to hold the switch in the up position for an extra 10 seconds. If that doesn't help, then you need to replace the regulator.
My regulator broke when I tried to lower the rear window and I heard a loud snap and the window was stuck open. The regulator is expensive (~$500).
