Shifter swap possible?
Old Feb 28, 2016 | 12:24 AM
jhanson25's Avatar
CLK 500, 2013 C300 Sport
Does anyone know if a shifter and shift boot from a aW204 will fit an 04' 500?? They sure look similar. I tried to cross reference the part number with no luck thus far. Thanks so much!
Old Feb 28, 2016 | 11:23 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Do you just want to replace the knob and leather boot, or the metal trim as well? The metal trim is a different shape and larger than the W203's but it's possible the wood (or metal) panel on the console could be altered to accommodate it. I would assume the knob mounts the same way (a lock ring underneath). The leather boot just snaps into the metal trim, and I am sure that could be adapted even if it weren't quite the right shape, though it could require cutting and/or stitching.
