Oil leak with Pictures, 270 cdi
Old Mar 3, 2016 | 12:22 PM
Reanimation's Avatar
270 cdi w209
Engine oil leaking on to aircon compressor, Does anyone have an idea where its coming from, the steering pump is located above and the oil filter housing to the left but its hard to see where this leak is coming from. I cleaned it all up went for drive and starts leaking again from above. Its not my top boost pipe I replace that. Second picture lower red circle shows an oil drop(ENGINE OIL) annoying me this. Also I've just removed all the boost pipes and clean all the oil out because I suspected they were the problem, but there all in good condition.
Attached Thumbnails Oil leak with Pictures, 270 cdi-20160303_114252.jpg   Oil leak with Pictures, 270 cdi-20160303_165608-2-.jpg
Old Mar 3, 2016 | 12:34 PM
270 cdi w209
The pipe above going in to the Steering pump is dry, I assume the steering pump is oil cooled???? I don't know, Thinking maybe getting someone to rev the engine whilst I look.
Old Mar 5, 2016 | 12:33 PM
floridawriter's Avatar
05 CLK55 AMG (1 of 247) Cubanitsilber designo series
If it were my CLK55 I'd look to the oil cooler. Don't know if your engine uses the same cooler system.
Old Mar 6, 2016 | 04:30 PM
270 cdi w209
I think I can see one behind the oil filter housing, wondering how its leaking so might have to strip it all down to get to it.
Old Mar 22, 2016 | 01:02 PM
270 cdi w209
Found whats leaking, its the steering pump, not sure exactly where from without taking it off. The fluid was mixing with spilt engine oil on the filter housing.
