Drive or reverse mode not moving =(
last year october I accidentally hit a goat. My radiator was replaced bec there is
oil or fluid (probably trans fluid) on reservoir,went to garage to fix and when they open the transmission pan there is a sign of water, drained and replaced all the fluid...since then i have no problem ..last two days ago I noticed there is something wrong with my car. i pulled over then turn off the key of the car.then start again put on drive and its not moving put on reverse still not moving. turn off the car for 3-5 mins put on drive then its moving, managed to go back home.the next day I used it again drive few kms heard a weird noise (its like whistling) pullover and turn off the car,start for couple of seconds put on drive not moving [only revs up] put on reverse still not moving turn off the car rest for 3-5 mins car starts moving again managed to go back home.tried it again in the parking area put on drive/reverse car is not moving.rest for 3-5 mins and its moving again. pls help guys..tnx
post any codes you are getting
tnx again!!!
btw im from middle east i cannot find this iCarsoft OBD.tnx for the advice Rodney.
My main seal is leaking so to prevent drips all over my floor, I taped down a pet pee mat. This has helped absorb the oil so it will not as Rudeney mentioned wicker up the wires to the TCU.
I would check the covers myself to be sure.
its been 4 days now... drive as if normal...
