Source for Replacement Side Marker Lights?
Old Apr 21, 2016 | 09:48 PM
Hk91308's Avatar
04' CLK, 09 997.2 GTS, 22 992 C4S
Evening MBworld-
Would you kindly suggest a good source to purchase replacement side marker lights for my 2004 CLK320 Coupe?
Driver's side light is out with error message coming on in my dash and externally the amber marker light is slightly chipped off, looks like some bicyclist or pedestrian nicked it, etc.
Perhaps this is a good time to change to clear side markers, please advise if there are good ones out there...
Many thanks as always friends
Old Apr 21, 2016 | 10:01 PM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
ebay
Old Apr 21, 2016 | 10:03 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I bought mine on eBay years ago. I think I paid about $20 for the pair. After a year or so, they became loose and would fall out, so I wedged some rubber grommets between the plastic clip that secures to the bumper and the bulb housing itself. This made them fit tighter and stay in place. I do get some moisture in them, too, but no major problems.
Old Apr 21, 2016 | 10:11 PM
Hk91308's Avatar
Thanks guys! Is there a specific vendor from EBay you recommend since my search showed quite a few vendors selling them...
Rudeney, I might just buy stock side markers to replace mine base on your feedback with the moisture and lights coming loose/falling out.
Old Apr 21, 2016 | 10:32 PM
gixxerboy's Avatar
i just looked, i bought mine from fishcake321 i've had mine for about a year and no issues.
Old Apr 21, 2016 | 10:36 PM
Hk91308's Avatar
Thanks so much gixxer, I'll check it out and give them a try..
Old May 8, 2016 | 12:13 PM
Hk91308's Avatar
Hope everyone is having a nice weekend.... Finally got some time to order these and wanted to get some feedback/tips on the installation :
Is it similar to these instructions on the E320
https://mbworld.org/forums/e-class-w...placement.html
or any better DIY pointers to get these installed once they arrive is much appreciated
Old May 8, 2016 | 10:35 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Old May 8, 2016 | 10:49 PM
Hk91308's Avatar
[QUOTE=Rudeney;6796607]
Thank you very much sir, you're my hero
Old May 9, 2016 | 08:43 AM
Yidney's Avatar
2008 CLK550 Cab
The recommended way is as Rodney shows it, but they are flimsy and it's not always as easy as it looks. It only takes a minute to remove a couple fasteners in your wheel well and reach your hand behind so that's how I do it.
Old May 9, 2016 | 07:20 PM
Hk91308's Avatar
Great info to know in addition, really appreciate it Yidney.
Old May 9, 2016 | 10:55 PM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Are the 04 the same as 05 used?
I ask because I have a set of practically new smoked side marker lights if you are interested?
I have clear on our car, so no need for the smoked versions.
-Nigel
Old May 9, 2016 | 10:58 PM
Hk91308's Avatar
-Nigel
Thanks Nigel, they should be the same I think..
I'm going with clear side markers but appreciate your gesture.
Old May 9, 2016 | 11:13 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Hmm, my side markers (both the OE's and my aftermarket clears) often pop out when washing the car. I put some rubber grommets behind the plastic tabs on the markers to help hold them more firmly in place.
Old May 10, 2016 | 01:20 AM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
Neither the OE or the aftermarket clear side markers I run now have ever popped out (except when I hit a piece of rethread). They are pretty snug....
Old Jun 1, 2016 | 03:08 PM
Hk91308's Avatar
I wanted to thank everyone very much for your help on this thread. My side markers were not as easy to pop out as the video, etc. this step via the wheel well made it easy peasy
Many thanks to all..
Old Jun 1, 2016 | 03:26 PM
Yidney's Avatar
2008 CLK550 Cab
One more thing. I got moisture in one of my two ebay clears, and Rodney mentioned that as well. Pretty easy fix. The light is two parts glued together - the lens glued to the reflector. The seam is easy to see when you have the light out. The Chinese skimp on glue since it is also a valuable ingredient in baby formula, so whether the glue is all the way around is hit and miss. You can either just wick some super glue into the seam all the way around, or I just mixed up a small batch of regular clear 5-minute epoxy and just smeared it into the crack where the seam is all the way around. No more moisture.
Old Jun 1, 2016 | 03:32 PM
Yidney's Avatar
2008 CLK550 Cab
Same here. I think mine would break for sure if I tried to pry them out.
Old Jun 1, 2016 | 09:16 PM
mis3's Avatar
2004 CLK320
One of my eBay clear lens broke when I removed them to get rid of the moisture.
Lessons learned:
1. Before installation, put some insulation on the seam between the reflector and the back housing. I would apply a think layer of caulking on the seams.
2. Once installed, do not remove them from the front. The reflector would break off from the back housing.
Old Jun 1, 2016 | 11:34 PM
Yidney's Avatar
2008 CLK550 Cab
I'd use glue and not caulk. Glue will be permanent, and the hole in the bumper is not large enough to accommodate a thick layer of caulk.
Old Jun 2, 2016 | 12:00 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Old Jun 2, 2016 | 09:51 AM
mis3's Avatar
2004 CLK320
Good point. The seller sent me a set of replacements last week. I applied thin layers caulk twice to the seams. I did not install them yet.
I found caulk is easier to apply to glue. For caulk, I can wipe it off but not glue.
I used glue to repair the old one and I made a small mess. Then I used acetone to remove the glue and the acetone also removed the shine of the reflector.
Old Jun 2, 2016 | 11:24 AM
Fatz's Avatar
mis3, I agree with Yidney on using glue rather than caulk. If you try to use regular glue, it tends to be too "runny" to properly apply.
Loctite, and probably others, make a super glue that is thicker and can more easily be applied to just where you want it. The version I use is for metal (black and blue bottle) but they also make it for plastics and wood. Available at home depot.
You can also put a drop of this stuff on the piece and quickly use a wooden object (like a popsicle stick) to dab the glue just where you want if you're not accurate enough doing it freehand.
Old Jun 2, 2016 | 12:44 PM
mis3's Avatar
2004 CLK320
I used Super Glue and it was hard to see and it ran. I used caulk because i have it in the basement!
Old Jun 2, 2016 | 02:18 PM
eteller's Avatar
2009 CLK 350
I need to do this fix, I think I have some Chinese baby formula in the basement i tried bulb grease on the light socket o-ring but it's now obvious it's the seam.
