Replace Flex Disc
Old Apr 24, 2016 | 11:04 PM
mis3's Avatar
2004 CLK320
Replace Flex Disc
The mileage of my 2004 CLk320 is 210k miles and the flex disc is still the original one.
I am going to do the ATF pan flush soon and I will ask the indie to inspect the flex disc.
How much is this flex disc? How may hours of labour?
Old Apr 25, 2016 | 03:47 PM
Patton001's Avatar
2006 CLK350
Flex disc shouldn't be more than half hour labour if that, but they will probably charge you at least an hour. It is a simple R&R job. Are you having symptoms of failure? If it is the original disc on there it is probably time.
In reality, it will only take them 10 minutes or so since they have the bottom pans off and working with air tools
Old Apr 25, 2016 | 09:45 PM
merceBENZ's Avatar
2006 Mercedes-Benz CLK500 Convertible
How easy to inspect it yourself? Do we have to remove anything?
Old Apr 26, 2016 | 03:34 PM
Patton001's Avatar
2006 CLK350
i can't remember if t is covered by any bellyplate, I have not removed mine on this car. I don't believe it is. But it is hard to really see if the rubber is tearing etc while it is installed. You almost have to remove it to inspect it and then you have it out anyhow. That is why I was asking if you have symptoms of it failing.
Old Apr 26, 2016 | 09:02 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I know the front one, at the transmission, is easily accessible. I think there is a heat shield that has to be removed to get to the rear one. They are not too hard to remove (I just removed the front one when I pulled the transmission). Watch the bolts and their orientation - they are different for the connection to the prop shaft vs. the transmission and differential. As for inspecting them just look for dried-out looking rubber and cracks. There may be some "lines", but you should not see cracks or any of the nylon reinforcement cords coming out.
Here's an example of a crack:
Old Apr 28, 2016 | 07:06 PM
Patton001's Avatar
2006 CLK350
yes, excellent example. Can't see that without removing the part.
Old Apr 28, 2016 | 08:21 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Generally, you would be able to see the cracks without removing the discs. Also, look for deformed areas where the bolts go through. But removal is fairly easy:
http://benzbits.com/w203/FlexDiscs.pdf
Don't let the "remove exhaust system" step scare you. You can access the front flex disc without doing that, and on the rear, all you need to do is disconnect the rear section, just downstream of the Y pipe, and you can probably move it out of the way enough to access the everything.
Old Apr 28, 2016 | 08:22 PM
mis3's Avatar
2004 CLK320
There are 2 flex discs, right? 30 minutes for both? Is one more difficult to replace than the other?
Old Apr 28, 2016 | 08:54 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes, two - see my WIS doc linked in my post above. I checked ASRA - shop rates list both at 4.7 hours total. I think this is due to needing to remove the exhaust and the rear engine (transmission) mount cross member. If you do this, I'd also suggest replacing the rear engine (transmission) mount, while you've got it all disconnected.
Old Apr 28, 2016 | 09:05 PM
mis3's Avatar
2004 CLK320
I did replace the engine and transmission mounts 2 years ago.
Should the 2 flex discs be changed together? Problem is I would probably not see the difference after the change.
Old Apr 28, 2016 | 09:14 PM
merceBENZ's Avatar
Damn, sounds like a lot of work for DIY. Don't like the part about exhaust removal.
Other than that is doable.
Old Apr 29, 2016 | 10:14 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Exhaust removal is nothing. Easy. Just use some penetrating oil on the bolts before trying to loosen them.
Old Apr 29, 2016 | 10:59 PM
merceBENZ's Avatar
It is heavy. How am I suppose to support it without lift? Given I have 4 Jack stands and floor jack.
Old Apr 30, 2016 | 10:55 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You do not need to remove the exhaust to access the front flex disc. You will need to remove the transmission mount, which means you will need to support the transmission. Although overkill for this job, Harbor Freight sells this:
http://www.harborfreight.com/450-lb-...ack-61232.html
With their usual 20% coupon, it's $80 and a good tool to have.
For the rear flex disc, you only need to remove the rear section of the exhaust - break it right behind the "Y". Then, as I said, you may be able to just push it out of the way for access. If not, then that transmission jack would work to support the exhaust for removal.
Old Apr 30, 2016 | 11:13 AM
merceBENZ's Avatar
What do you mean under breaking exhaust?
Old Apr 30, 2016 | 11:23 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
"taking it apart" or "disconnecting it". There behind the Y, you'll fine a coupling held together with a few (3?) bolts.
Old Apr 30, 2016 | 11:29 AM
merceBENZ's Avatar
Oh, that's better. So, when we should replace it? Given that you have to perform such talk I would replace them right the way. Symptoms? Time frame? Mileage?
Old Apr 30, 2016 | 11:36 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The flex discs really only need replacement when (if) they begin to show signs of damage. Honestly, failure is rare. There are cars on the road with 200K and more with perfectly good flex discs.
Old Apr 30, 2016 | 01:36 PM
merceBENZ's Avatar
What is the factor than? Time?
Old Apr 30, 2016 | 09:56 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Time and environment are factors in rubber deterioration.
Old Apr 30, 2016 | 11:13 PM
merceBENZ's Avatar
I know that. I meant car symptoms. It is quite work just to see how they look. I think I have to feel first.
Old Apr 30, 2016 | 11:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
There are usually no symptoms, that's why the B service indicates that they should be visually checked.
Old Apr 30, 2016 | 11:44 PM
merceBENZ's Avatar
DO you want to say that they take stuff apart just to check on it? I mean disc.
Old May 1, 2016 | 10:41 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The only part you need to remove to inspect the flex discs is the exhaust heat shield at the rear (part 105c in the WIS doc I posted earlier). The front can be inspected without removing anything. You only need to remove the transmission support and exhaust pipe for access to REPLACE the flex discs.
Old May 1, 2016 | 10:46 AM
merceBENZ's Avatar
Could you give a link to the WIS post again?
