3rd brake light fix?
Old May 2, 2016 | 02:03 PM
irokdastar's Avatar
2004 CLK 500
My third brake light stops working every now and then . Is there a DIY fix or do i need to get a new one?
Old May 2, 2016 | 03:33 PM
Patton001's Avatar
2006 CLK350
Not really anything to fix unless a wire is broken. They are pretty much just plug and play. I got one on ebay for around $100 US
Old May 2, 2016 | 04:53 PM
JimVonBaden's Avatar
2005 CLK500
If it is intermittent it is either a broken wire or a plug with a bad connection. pop the cover and trace the wires around.
Old May 2, 2016 | 11:52 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's a weak/broken solder on the circuit board inside the LED bar. You can cut it open and fix it, but honestly, I'd just spend $80-$100 on eBay and get a replacement.
Old May 3, 2016 | 05:38 PM
irokdastar's Avatar
2004 CLK 500
Yea I went that route . I just ordered a new one waiting to get it . I thought maybe it will be am easy simple fix but I am not going to bother.
