Engine mount sleeve/cover??
Old May 11, 2016 | 11:09 AM
zip439's Avatar
CLK 500, yr 2005
I'm going to be replacing my engine mounts. The right is leaking.
Question:Is the outer part of the mount just a sleeve or cover? Can I reuse the old sleeve/cover? I'm asking because pictures of new Lemforder mounts seem to indicate that the outer cover or sleeve just slides over the actual mount and the cover would cost an extra $20.00. If I can save $20 why not?
Old May 11, 2016 | 09:06 PM
floridawriter's Avatar
05 CLK55 AMG (1 of 247) Cubanitsilber designo series
Are you talking about the metal heat shield or the white teflon heat shield?
Old May 11, 2016 | 09:37 PM
zip439's Avatar
CLK 500, yr 2005
Question
The white teflon shield. I can purchase the mount with and without the teflon shield. My car is a 2005 and the right mount is leaking. The right side looks to be a lot easier to replace than the left. Can you get them both replaced without removing the exhaust pipes?
Old May 11, 2016 | 11:23 PM
You want the teflon heat shields. The mounts fail as much from heat as from material. The teflon is a better insulator than the metal shield. You'll have to drop the exhaust to change them.
