'03 CLK 320 passenger heated seat??
If you have a volt meter, it will help to find the culprit line or contact.
If the lights do not illuminate, the UCP is not getting a signal from the seat controller. Assuming the power seat works, then it's not the seat controller. I would then suspect either the wiring where the heating elements plug into the seat controller is bad, or the heating elements themselves are bad.
