Engine Mount Install DIY
1) You will be working around the starter, so disconnect the battery so you don't have sparks flying.
2) Jack the front up and get it on solid blocks; remove both of the under engine pans/plastic shields.
3) Loosen both of the sway bar bushing brackets, then remove the sway bar from the right wheel. Then remove the right sway bar bracket. This will give you the room you need to get the engine mount removed and the new one installed.
4) Raise the hood all the way up; remove the air box engine cover and place your lifting chains on the engine.
5) Back under the car loosen both the left and right engine mount bolts from the bottom of the mounts. Do not remove the left bolt just give your self about 3/8" slack so when you lift the engine the left mount can ride up some but not become disengaged from the frame. I did this thinking the realignment on the right mount would be easier if the left mount remained in its place.
6) Now you loosen the top bolt of the right mount. I did not have the physical strength to break that bolt loose. You are working on your back under the car with your hands up between the exhaust and catalytic converter near the starter. It is tight and difficult. I could not find a way to work from above, or from the front end of the car. The design of the metal heat shield around the engine mount forced me to work from the rear in the space near the catalytic converter. Here is where I was lucky to have the ratcheting 5/8" wrench. I got it onto the top bolt and then using a pry bar through the other end of the wrench I was able to leverage with the pry bar against the engine block and got that top bolt broke loose. But that was only half the story. It took at least one hour to get that bolt completely backed out. I could not move it with just my finger tips until it had only two turns left on it. Maybe because the old mount was broke at the top rubber, but I had to use a wrench for damn near the enter removal and you can only get about 15 degrees turn without before removing and resetting the box end of your 16 mm wrench to turn in the confined space. Because the mount sits at an angle I had difficulty using the open end, because it is straight on the wrench, whereas the boxed end is angled and that allowed me to get the wrench on to the top of the bolt and make the 15 degree turn. THIS WAS NOT FUN! Patience required!! NOTE: This top bolt will not come completely out. It is too long to be removed from the arm of the engine mount support. The top of the bolt hits the exhaust manifold, but it will clear the top of the engine mount when you get it raised as high as you can get it. This top bolt also retains the metal heat shield in its place.
7) Now you can completely remove the bottom bolt from the engine mount, raise the engine (carefully) with a hoist. I found it useful to get a second jack under the right side of the engine and with the use of a piece of small wood to spread the load I continued to raise the right side of the engine from the mount of the alternator. NOT THE ALTERNATER! The area where the bolt holds the alternator to the block. There is an area where you can safely raise the engine a bit higher with a jack. That was the trick for me to get the necessary room to remove and install a new engine mount. The limiting factor for how high to move the engine seems to be the lower radiator hose. You will get that hose pretty tight. I was concerned also with the rear of the engine at the firewall, but that seems to be OK.
8) The new engine mount will go in with a new teflon heat shield; Though I think the old one would have been reusable. To get the new mount in place you must be sure that top bolt is raised out of the way. I used a wadded up Scotch Brite pad between the metal heat shield and the support arm to wedge that bolt up and out of the way. There is a pin that sticks up on the top of the engine mount. It positions the teflon heat shield and the mount itself to the engine mounting arm, so be sure you have it aligned properly! Also on the bottom of the mount there are four indents, two will match raised edges on the cars frame. (See the pictures) All these must be aligned. I did this by very slowly, about 1/16 of an inch at a time, lower the jack that was at the alternator attachment and then move the mount by hand to check its placement in relationship to the previous mentioned alignment points.
9) Now you get to start that top bolt into the engine mount. I did this while there was still some play in the engine mount when lowering the engine into position. I was also able to get most of that bolt threaded down into position by hand. Before placing all the weight of the engine on the mount get your lower bolt started as well. Everything should be lined up. Remove the jack from the alternator area and tighten that top bolt.
10) Lower your engine hoist and tighten both the right and left engine mounts bottom bolts.
11) Reinstall the sway bar at the wheel and tighten. You will find it makes it easy to reinstall the sway bar brackets by jacking the right wheel up. It will force the bushing into its proper place and you can position the bracket and tighten it. Also retighten the left sway bar bracket.
12) Reinstall both of the under engine plastic shields: remove the blocks from under the car.
13) Reconnect the battery.
That's how I did it. If you have a better system please let us all know as this was not fun. There is a lot of crawling under from the front then reposition to the rear; then get up and do something from the top. Then down again.
GOOD LUCK.
Hahah.. not something I'll be doing.
