CLK550 Brakes
2015 E550 Cabrio, 2007 CLK550 (SOLD)
CLK550 Brakes
Just wanted to know what kind of brake setup a 2007 CLK550 has? Is it a 2 piston front - 1 piston rear setup? If so, would it be relatively easy and inexpensive to upgrade to a 4 piston - 2 piston setup of a CLK 55 (03-04), SLK 55 (03-04), C 55 (03-04), C 32, SLK 32 for example? I believe that the models I just mentioned all have the 4- 2 piston setup, yes? From what I know, the 6 - 4 setup is much more expensive and could need a new master cylinder which is not what I want to get into.
Thanks, Moe
Thanks, Moe
Nahhas26 (08-04-2016)
00 C200 & 00 C55 & 06 SLK55
+1,
Your Clk500 sharing the same Front & Rear Rotors dia. with "W203 C32/C55/W209 Clk55",,
which is (345x30) Fronts & (300x22) Rears, but NOT drilled..
,,ZAYED,,
,,ZAYED,,
