Keyless go issues-replaced handle still no go
Old Jul 8, 2016 | 08:22 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Hello everyone,
As the title states. 2005 clk55. Replaced keyless go door handle one drivers side with a new one from pelican parts, still does not work. Keyless go works on passenger side and starts up with the engine start button on the shifter, hooked it up to a diagnostic machine and it says it's not detected...took it apart three times and put it together just to make sure and still nothing, doesn't lock or unlock with keyless. Manually pressing on the key does work
Please let me know if you have any suggestions or possibilities. I already checked fuse box under the hood and fuses on the side by steering wheel thank you all for your time
Old Jul 8, 2016 | 09:53 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Sounds like it's a bad antenna in the driver's door and not the handle.
Old Jul 9, 2016 | 04:00 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Than you for the reply. I'm on mobile and will search for a diy online...now that I have you here another question...
I've been trying to smog my car for four days now and the secondary air pump is still showing as incomplete...I tried the procedures of Doing a cold start and idle with ac and rear defroster for 2.5 minutes to no avail...any other tips? I really want to register this car
Old Jul 9, 2016 | 10:05 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Try this drive cycle:
http://benzbits.com/Drive_Cycle_Readiness.pdf
Old Jul 9, 2016 | 10:16 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Here is some info on KeylessGo that might help:
http://benzbits.com/w209/KeylessGoComponents.pdf
http://benzbits.com/w209/KeylessGoDiagram.pdf
http://benzbits.com/w209/KeylessGoParts.pdf
The left and right door antennas are the same, so you could test my theory by swapping them. Here's how to remove the door panel:
http://benzbits.com/w209/DoorPanel.pdf
Old Jul 9, 2016 | 12:05 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Thank you so much for your help. Are these universal for all Mercedes? I looked on parts.com and I found a control unit for the keyless go listed at around 400$
Part number 2098202226
Does this sound like the right one?
Thank you again for the help sir
Old Jul 9, 2016 | 01:08 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Quick update...it was the antenna part number is
2098202226
I swapped it out as rudeney suggested and it worked on the driver side thanks for the help...now to smog this car
