Clunking from rear suspension (driver's side) after coil springs replaced
Thinking it was some bad spring dampers, I replaced the rubber dampers that go over the tops of the springs and that stopped the noise in the passenger side rear, however the driver's side still clunks.
The sound is definitely metal on metal and is at any speeds, more so fast bumps. Slow speed bumps don't make much of a sound.
Things I've tried:
Torque everything to spec while the wheel is under load
Sway bar and links look to be OK
upper shock mount is snug, but I didn't torque it down. not loose for sure
spring is seated properly in the lower notch and the upper damper is fine
Let me know if you have any suggestions, they are much appreciated! I am flummoxed...
