Faulty Thermostat?? Not Sure??
Old Sep 8, 2016 | 09:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Well, it sounds like you do need a conductor plate!
Old Sep 8, 2016 | 09:54 PM
Timewarpone's Avatar
05 CLK320 Cabriolet W209 & 2011 BMW X3
Just guessing, are the speed sensors the 6 solenoids on top of the speed sensor?
Old Sep 8, 2016 | 10:00 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Noe, the solenoids control the flow of fluid through the valve body. The speed sensors are Hall Effect sensors (i.e. magnetic detectors) built into the conductor plate.
Old Sep 8, 2016 | 11:33 PM
Is it wise to drive the car 25 miles or have it towed? Thanks
Old Sep 9, 2016 | 09:16 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It is OK to drive in limp mode, but it will be annoying at best. It will basically be locked in 3rd gear, and the torque converter lock-up will be disabled. It will feel like it;s Motor boating". Other than avoiding situations where you need strong acceleration, it should be fine.
