Windows stay open after i get out of the car?
03 CLK 320 A209
Just finished fixing the left rear window regulator and put battery back in but now if i exit the car the windows on my coupe don't go back up they stay slightly open... same thing with passager side literally all 4 stay open.
When you disconnect the battery, you need to re-sync the windows. Do a search, but I think it is that you put them all the way down, and hold the button down for five seconds.
MBworld Guru
Yep, you need to re-sync the windows. For each one, lower it about halfway, then raise it fully and hold the switch up for an extra 5 seconds once the glass is closed.
03 CLK 320 A209
Thanks guys it worked and now they all close, I'm about to clean the EGR since I threw a code is there any guide you recommend? also do yall know what that stick is for between the firewall and the motor next to the battery?
