A209 wont go over 2k RPM
03 CLK 320 A209
So I just finished putting back the EGR Valve in my A209 but now that I'm driving car wont even drive without limping almost as if it wants to turn itself off.
03 CLK 320 A209
03 CLK 320 A209
update: so I started up the car after I did the throttle reprogram and when I pressed the brake to put it on reverse it started revving it self and then it completely shut off, right after that I turned it on and try revving it a little and it did then dropped rpms and completely shut off once again
update: so I started up the car after I did the throttle reprogram and when I pressed the brake to put it on reverse it started revving it self and then it completely shut off, right after that I turn Ied it on and try revving it a little and it did then dropped rpms and completely shut off once again
03 CLK 320 A209
