Coolant Tester
Reading the instruction, this tester can determine the boiling point of The coolant. Did anyone try something like this? What should be the boiling point of the coolant.
If you want to be certain, and you can't see any sludge in the expansion tank, I'd suggest sending a sample off to a testing company.
The coolant was changed back in Oct-2011 when they changed the water pump and thermostat. I have driven maybe 50k miles after the coolant change. It's probably too early to change.
If you have ATF or oil in the coolant, something has gone wrong and needs fixing.
