Coolant Service
It's a Dec' 2006 car, I don't know if the coolant has been replaced, I shouldn't imagine so, the dealer said it should have the 15yr long life stuff in it. Car has about 130k miles. I'm not sure whether to get some coolant and just top it up, or whether to drain the coolant and fill with fresh long life mb spec fluid.
What are your opinions?
Tia, Ben
i was flushing my using a hose and then when empty i used distill water and run the car for like 5minutes and empty it and refill will do again as soon it warms up !
If you are going to add "water", use only distilled water. If you are going to add coolant, get a compatible coolant and mix 50/50 with distilled water. Until you find the leak, I'd top it off. Once you find and repair the leak, then go ahead and do a full coolant change.
