clk 200
clk 200
Dear Friends.
I have a clk 200 2002 model I am having trouble w/ seats of cars if I try make it forward its go if I try make it backwards its go forwards only button is working in one detractions only if u push it back seats will go in front.
any idea how to fix it.
Thanks.
Thanks.
MBworld Guru
Try resetting the door ans seat controllers by pulling fuses 21, 22, 27, 29, 34, and 38 and 40. If that does not help, then it's probably a bad door controller or bad seat controller or a wiring issue that will require proper diagnosis to resolve.
MBworld Guru
SO before pulling fuses, only one side was problematic, no both are? I'd pull fuses again and wait a few minutes to see if anything resets. This problem seems like the servo (motor) has lost its calibration and removing power should reset it.
