Need help - CPS replacement
Should the top part of the MAF come off of the elbow just by pushing back on the retaining metal clip at he rear of the MAF where the top and the elbow meet? Videos online are of different models and are rotated back and up to remove the entire assembly. The 550 has the plastic tabs at the very top, so rotating the entire assembly doesn't seem doable. It seems to me that the top and bottom are removed separately and the rear metal clip is all I see holding the 2 pieces together but it won't come loose.
I have the top rubber hose and the AOS hose disconnected. Disconnect the AOS hose at the AOS end.
Need help getting the (#%#* thing out.
