CLK Roof! Release rollover bar problem...
CLK 320 W209
My CLK was all going well! Then one day I jumped in and the red warning "please release rollover bar" came up on the screen. I have put the headrest up and down a thousand times and it still doesn't go away!! Some times the windows will go down, but only a bit at a time. I want to use it for the summer and its out of MOT so I can't drive it anywhere to get it fixed. Please help, I have completely run out of youtube videos!!
MBworld Guru
It could be a faulty microswitch in the roll bar system. You really need to get it hooked up to SDS to get the underlying error codes and use its actuations to test the system.
Yes, It did got resolved. There is a fuse which is not marked as a fuse related to Rollover bar located on left side of Driver side bay. Check all the fuses and see if anyone of them blown and replace it. I did the same and it was fixed. Sorry i forgot what is the number or location of the fuse.
