Help with trouble codes
Old Apr 24, 2017 | 06:58 PM
mbgator's Avatar
2008, CLK 550
2008 CLK 550, 124k miles. Check engine light came on. Checked the codes and am getting P0025 and P0015. Both indicating exhaust bank, right camshaft retarded. Is this an oil issue, sensor issue, or something else? Mobile 1, from new, every 5000 miles.
Thanks for any help.
Old Apr 24, 2017 | 10:56 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
See here for a translation of those generic OBDII P-codes to MBZ-specific DTCs:
http://benzbits.com/DTC/DTC%20209.372.pdf
You will find that P0025 = 0064 and P0015 = 0060.
Now, look here at Scenario #2 (page 4):
http://benzbits.com/BalanceShaftTSB.pdf
You have bad camshaft adjuster solenoids (a.k.a. cam magnets). Replace all four of them. If you want to DIY, it's not terribly difficult and you can buy all four for about $100:
http://www.mboemparts.com/oe-mercedes-benz/2720510177
It would just be removing three bolts per sensor, except that one is behind the oil cooler, so you'll have to drain a gallon of coolant from the radiator and remove it for access. Maybe 2-3 hours in the garage.
Old Apr 26, 2017 | 10:39 PM
Yidney's Avatar
2008 CLK550 Cab
Having removed these recently to replace the seal on each sensor, I recommend you get a new seal for the oil cooler as well. A new seal is soft and pliable - the old one is crusty weirdness. I would not trust it to seal twice.
