Ideas for wheels?
Old Apr 27, 2017 | 12:24 PM
irokdastar's Avatar
2004 CLK 500
Ideas for wheels?
I am looking to get wheels for my car . I will be dropping the suspension with new springs the drop is about 1.2" all around . I was looking for 19 or 20 . What would work best ? I would like to get more tire sidewall . Any ideas on offset ? looking to do concave style
Old Apr 27, 2017 | 12:48 PM
Yidney's Avatar
2008 CLK550 Cab
Personally, I think anything bigger than 19 looks wrong on these cars. Others have said the same. Plus, that's how you get more sidewall. As for offset, you need to decide what width wheels you want. Then you can do the math from there. Basically, to have your wheels clear things on the inside exactly as they do now, you need a lower offset number that is equal to 1/2 of any increased width.
Old Apr 27, 2017 | 12:53 PM
irokdastar's Avatar
2004 CLK 500
I am looking to do staggered wheels . so 8.5 front and 9.5 rear . My main issue is the calipers I have the sport brakes and I don't want to have issues with it touching .
Old Apr 27, 2017 | 12:57 PM
Yidney's Avatar
2008 CLK550 Cab
And to be clear - I mean the change in offset should be equal to 1/2 the increased width, not the total offset. So if you get 1"wider wheels, that's about 25mm. 1/2 of that is 12-13mm. So if your current offset is 40, then something around 28, plus or minus, will give you the same clearance. But that's not an ironclad rule. You have room to play depending on how much clearance you have now, tire style, etc.
Old Apr 27, 2017 | 01:05 PM
irokdastar's Avatar
2004 CLK 500
I see . I am thinking its better to buy wheels locally than online.
Old Apr 27, 2017 | 01:44 PM
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
which wheels are you thinking of getting?
Old Apr 27, 2017 | 02:13 PM
irokdastar's Avatar
2004 CLK 500
I had these in mind . All in silver . going on a silver car
http://www.ebay.com/itm/19-Niche-For...ZXcv0c&vxp=mtr
http://www.ebay.com/itm/19-ZENETTI-M...VX3GqL&vxp=mtr
