Jack Point Replacement
Old Jun 12, 2017 | 02:25 PM
Monty3038's Avatar
2008 CLK 350
So, my 2008 CLK 350 had a flat today... and when I broke out the Jack and associated items to put the spare on... the jack point/guard is broken. I was able to fix it enough to get the spare on, but the hard plastic piece that mounts into the frame rail, using some sort of 'push-in' connection, is broken and fell off.
Is that part readily available? If not, how does it remove from the vehicle (looks like a one-time push in) so that I could go to a pull-a-part and obtain one?
Old Jun 12, 2017 | 04:54 PM
Monty3038's Avatar
2008 CLK 350
Found the part on AutoHauz, has anyone had experience with replacing one? Are they pretty universal and fit pretty well? Just hate to get stuck somewhere and not be able to jack up the wheel due to lack of this pad...
Old Jun 12, 2017 | 06:55 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's just held in place with a plastic push-pin. Remove the old one, place the new one, insert the pin, and press it in place. I had to replace one on the CLK and one on the SL. Somehow, they went missing.
Old Jun 12, 2017 | 07:09 PM
Monty3038's Avatar
2008 CLK 350
Thanks, interesting enough, I found the missing on, it was embedded in the lower trim panel near where it goes... without a pin in it... will order a new one to get the pin and replace... weird. May be when I drug the bottom of the car in a flash flood (not enough to cover sills but enough to screw with the gravel road enough to make 6-8 inch divots.
Thanks for the advice!
Old Jun 14, 2017 | 03:09 PM
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
For anyone looking I offer the pads at this link
https://www.fcpeuro.com/products/mer...pad-2039970186
Strangely this was one of the first repairs I made to the CLK Project car.
--Kyle
