install subwoofer
Old Jun 20, 2017 | 01:34 PM
clkmusipa's Avatar
2003 CLK320
install subwoofer
i want to install a subwoofer in my clk but dont know where to start. i have a sub with built-in amp. want to put it in boot so also need advice on where to tap into for power and line-in etc. i have a 2001 clk320 it has two rear deck speakers with the bose logo on the casing
Old Jun 23, 2017 | 09:16 AM
clkmusipa's Avatar
2003 CLK320
anyone?
Old Jun 23, 2017 | 09:48 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
2001 CLK = W208 - you are in the wrong forum - this is the W209 forum.
Old Jun 23, 2017 | 10:06 AM
clkmusipa's Avatar
2003 CLK320
my bad
ah snap its actually a 2003 clk320
typo error
Old Jun 23, 2017 | 10:20 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
MY2003 CLK320 Coupe, right? Because the MY2003 cabriolet was still a W208. OK, so you might want to fix your forum user's profile. While you're in there, add your location (at least country)
So, assuming a MY2003 CLK320 coupe W209...
You already have a subwoofer in the rear hat shelf. Assuming your amp has high-level (speaker-level) inputs, I'd tap in there. It would probably be best to disconnect the factory speaker. If your amp does not have high-level inputs, you'll need an adapter that will convert from speaker-level to pre-amp level. If that does not make sense, then I suggest getting a friend or shop experiences in car stereo system to help.
As for getting power to the amp, there is a fuse block in the trunk. Here's the diagram:
http://benzbits.com/w203/RearFuses.pdf
It's for a W203 C-Class, but it's the same for the W209. The sockets on circuit 15R are switched with the ignition, so use one of those. What I'd do is use a fuse tap like this:
