Window Rattle
Old Jun 30, 2017 | 11:16 AM
Gedk's Avatar
2016 C200
Window Rattle
I have a 2016 C200 Estate which has rattling windows. Dealer has had car in 4 times now but rattle always returns after a short while. Is there a factory fix for this problem, its driving me crazy? My previous C Class estate (2007) did not suffer from rattles at all!
Old Jun 30, 2017 | 12:53 PM
xsever's Avatar
2012 C300 4MATIC Sport
This is the CLK forum not the C forum. Thread should be moved to the C forum. Good luck with a fix.
Old Jul 7, 2017 | 09:26 PM
cstevenson's Avatar
2011 S550 4Matic
Mine rattled until I adjusted the two bolts on the bottom of the door frame: turns out the washers had worked themselves loose. The screws are located under rubber grommets that you can pull out.
