brabus integrated light on amg side skirts
CLK500
now the skirts light will only light up when the roof light is swatch on, if you want only to light up the skirts lights when you are driving, you have to cut off the roof reading lights and collect to
skirts lights, remind to delete the fault code from the computer
CLS350
nice ride man.. funny thing is i saw a CL with a similar set up as you, it was black with black painted brabus monoblock VI and a brabus body kit. It was at some body shop i forget where exactly.
GF
One word.. "PIMP"
I believe VENTUNO now makes LED foot illuminations also..
it has 5 LEDs intergrated in one puddle, It look just like SAMUEL's or maybe brighter
I will check it out soon.
Cheers
Cheers
CLK500
THE CL IN FULL BLACK BRABUS IS MY FRIEND, HE JUST FINISHED
FROM THE BODY SHOP, THAT IS THE NICE JOB WILL TAKE SOME
PHOTO WITH HIM NEXT WEEK AND POST IT.
THERE IS OTHER LED LIGHTS SUPPLIER FROM JAPAN, CHECK
IT OUT AT www.algernon-div.com
FOR CLK MAXIMUM CAN PUT 4 LIGHTS EACH SIDE, IF YOU
WANT THE LIGHT SWATHES OFF WITH TIMING DELAY
"FROM BIGHTNESS TO WEEKNESS" SAME AS THE ROOF LIGHT,
BUT IF YOU DON'T MIND IT WILL BE SWATCH OFF ONE SHOT,
YOU CAN PUT ADDITONAL RELATE INSTALLED INSIDE THE
ROOF, THEN YOU CAN PUT 5 LIGHTS EACH SIDE, IT IS ONLY
W220 & W215 CAN SUPPORT ENOUGH POWER FOR 5LIGHTS
EACH SIDE FROM THE ROOF LIGHT. THE JAPAN LED LIGHTS
SYSTEM IS MUCH BETTER BECAUSE THEY COME WITH OPTIONAL TIMING DELAY, BUT BRABUS IS NOTHINGS ELSE EXCEPT THE LIGHTS
#34
CLK500
ATTACHED SOME CLEAR PICS OF MY CAR
http://www.stlhosting.com/upload/PICT0350.JPG
http://www.stlhosting.com/upload/PICT0352.JPG
http://www.stlhosting.com/upload/PICT0354.JPG
http://www.stlhosting.com/upload/PICT0355.JPG
http://www.stlhosting.com/upload/PICT0357.JPG
http://www.stlhosting.com/upload/PICT0362.JPG
#40
CLK500
i have try pss9 before but too stiff for me to drive in HK,
so i use now is brabus shock with eibach spring
front cut off 5" and back cut off 2" length with 1point pad,
it is almost same ride comfortble before cut the spring
but the ride high can drop like pss9
#47
98 W210 Advantgarde
Did you get your car done at "Kolo" too? I do some of my stuff there but the set up's just too crammed for my liking and kolo himself isn't much of a tuner IMHO. Tezta and I were in the area getting some upgraded tailight for my ride just a few weeks back, that's when we saw your friend's CL. Great to see another HK member here.
#49
98 W210 Advantgarde
yes ! some job is done by kolo, my friend the CL is already done
will take some photo with him soon.
#50
GF
Hi Frisco,
How is the ride like for 5f/4r fwiw? whats fwiw?
is it hard or uncomfort with your current setting?
whats the best setting if I have 18x8.5F and 10 at rear ?
