How do you get the fan out?
Old Jul 20, 2017 | 09:42 PM
06SL500AMG's Avatar
2006 SL500
I've gotten the fan loose but it hangs up on metal lines on the passenger side or the upper radiator hose on the drivers side. How do you remove the upper radiator hose clip or is there a way to remove the fan without removing a hose and not breaking a plastic clip? I'm trying to get my alternator out. I've heard of lifting the engine, but I don't want to smash the oil pain or do any damage under there. I've searched and I cannot seem to find these instructions.
Old Jul 21, 2017 | 12:00 AM
Yidney's Avatar
2008 CLK550 Cab
What car do you have? I had the fan out of my 550 not long ago to do the water pump. Lots of stuff to remove but not all that hard.
Old Jul 21, 2017 | 03:05 AM
06SL500AMG's Avatar
2006 SL500
Clk 500. I can get the fan loose, but I can't get it around the hoses. What hoses did you have to remove?
Old Jul 21, 2017 | 05:05 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
This is for the M272/M273 engines, but it should be essentially the same:
http://benzbits.com/w209/EngineFan.pdf
Old Jul 28, 2019 | 10:03 AM
MYCL65AMG's Avatar
2005 CL65 AMG
Disconnect the metal transmission cooling line on top of radiator on the passenger side and move it back out of the way and your fan should come out on an angle, passenger side 1st.
