Car jerks when accelerating
Old Aug 20, 2017 | 10:21 PM
cstevenson's Avatar
2011 S550 4Matic
So I replaced the transmissions conductor plate and the problem hasn't changed. The good news is that it doesn't seem to be getting worse. I also scanned the TCU with one of those iCarSoft units and it said there were no error codes.
After living with the problem for a month or so, I'm pretty sure that it's the torque converter locking up when it's not supposed to. Does anyone know of common failures associated with the torque converter in this transmission? (722.6)
And I've nearly got my ac problem sorted out, it turns out the pulley bearing seized up and jammed the V belt. The compressor itself seems fine.
Old Aug 21, 2017 | 10:57 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I seem to recall some issues with the lock-up solenoid. You probably need to get it on SDS to do some tests.
Old Dec 29, 2019 | 04:46 PM
Idris Ogee's Avatar
2003 CLK 320 Convertible Coupe
Car Jerking
Hi cstevenson, Compliments of the season,please did you sort out the jerking issue??my 2003 CLK has exactly the same problem to a T!
Old Dec 29, 2019 | 05:04 PM
cstevenson's Avatar
2011 S550 4Matic
I never figured it out, I actually wound up selling the car.
If I were you, I would try replacing the solenoids and the conductor plate.
Old Nov 3, 2020 | 01:21 AM
Jonny Setiawan's Avatar
w212
Hi Rudeney,
My W212 E300 2009 experienced coolant mix in the transmission fluid. They flushed it out and changed new radiator. They even recommended to change to a new TCM as the old one is bloated like a bloated lithium battery. But now I experience jerk when ever the gear shift at 20km/hr. Any idea what should I do? thanks.
Old Nov 9, 2020 | 03:56 PM
echanlyn's Avatar
CLK500
Tranny Issues
I went thru this exact experience earlier this year, and all the symptons which you mention. I had to get a transmission service, which included replacement of the pan and fluid. Get it done quick before you get stranded.
Old Nov 11, 2020 | 01:42 PM
  #32
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
search for "jerk in the transmission"
Old Jul 14, 2021 | 03:09 AM
  #33
Hk91308's Avatar
04' CLK, 09 997.2 GTS, 22 992 C4S
My 04’ CLK320 with 139k miles started to have this issue, where car tends to jerk a couple of times when I accelerate, and it's very uncomfortable. It happens at different gears, and different speeds, but usually not highway speeds. similar to what OP reported…any recent updates to this as a remedy. My trusted mechanic is back in CA and I am currently in Las Vegas ..no known reputable MB indy shops out here, and I’d like to get it back to CA to my mechanic to assess and repair, would I risk any underlying damage or being stranded if I pushed this to drive back to CA 8-10hrs?
my car has all services up to date - suggestions and feedback most appreciated as always, thanks friends
Old Jul 14, 2021 | 08:11 AM
  #34
insame1's Avatar
Car will be fine. Look at the post above yours.
Old Jul 14, 2021 | 08:41 AM
  #35
cstevenson's Avatar
2011 S550 4Matic
I tried replacing the fluid, filter, and contactor plate, nothing worked. I don’t think I tried replacing the solenoids though, that might be worth a shot. I sold the car before I tried the solenoids.
Old Jul 29, 2021 | 06:01 AM
  #36
amusa's Avatar
16 GLE400 4matic
The solenoids are mounted on the conductor plate (Valve body plate). If you change that you should of replace the plug as well
Old Aug 22, 2021 | 03:42 PM
  #37
Hk91308's Avatar
About two weeks ago this problem developed: the car tends to jerk a couple of times when I accelerate, and it's very uncomfortable. It happens at different gears, and different speeds, but usually not highway speeds.
Coupled with this issue (I couple them because they developed at the same time) is that when I give it gas to climb a hill (however slight), the RPMs get stuck at around 1,000 and the car rumbles exactly like if you try to climb a hill without downshifting. The car will continue to rumble, and keep the rpms at 1,000 rpm until I floor it (or basically give it A Lot of gas, then they shoot up and I actually start accelerating.
I originally thought it was a wheel bearing I knew was worn, so i replaced that one and checked the other three, but to no avail. There are no error codes.
Would STAR diagnostics tell me anything about transmission issues?
Any thoughts would be appreciated!!
ETA in case anyone has similar issues - my indy performed as transmission Reset and perform shift adaptations, all works fine now 3k miles later. $150
