Power trunk needs help...
Old Jul 28, 2017 | 04:51 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
anyone else have issues with the power trunk buttons on the trunk itself? Often I'll press the lock button, and it will start to close then stop. If I then press the close button, it will sometimes close, sometimes do the same start and stop, but I can "help" it with a thumb on the button and a little finger pressure on the trunk itself. That technique won't work with the lock button though.
If I'm on the way out (as opposed to just got home) I can jump in the car and close with the button on the driver's door no problem.
Old Jul 28, 2017 | 11:53 PM
Yidney's Avatar
2008 CLK550 Cab
So you have the trunk with the power close option? If so, you probably won't get a lot of responses because based on just looking at cars for sale that may be the rarest option of all. I have it, but have never had a problem with it.
Old Jul 29, 2017 | 08:52 AM
eddieo45's Avatar
yours always closes, whichever button you press? hmmmmm..
Old Jul 29, 2017 | 10:29 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I doubt it has anything to do with the buttons themselves - the just send a momentary signal to the soft top controller and it does the work by operating the hydraulic pump and opening the proper valve to operate the cylinder for the trunk lid. Assuming the soft top works with no problems, then I suspect the trunk lid cylinder is failing.
