power steering scare w209
I installed a used PS pump and was not too bad to do , well after all my hard work I stated the car added fluids and the steering was good
There was allot of ai bubbles for about 5 min and a bit of nose but is all settled down. All was good for about 20 min I can home ,then I went back out 3 hours later and the steering was bad again WTF
so Im thinking the original pump was fine and its something else but what?
http://benzbits.com/w209/PowerSteeringBleeding.pdf
Note that it mentions how difficult it is to remove trapped air. I heard one guy who said he had to turn his steering wheel back and forth hundreds of times to finally get all the air out. He also manually rotated the pump a few turns after every 10 steering wheel cycles.
The reservoir is technically not part of the main pump..There is a clip that helps the reservoir attach to the pump....If you look at this picture there is a clamp in the middle or top of the cut hose is there is a coupling in there what is that ? could is be blocked what that? its the return hos I thinks. I was looking at that yesterday and felt is as if there a filter in there maybe it clogged and since I'm reusing it I have the same result as the old pump? the reservoir is not the original ...The fact that it was drained when I replaced i could have un clogged or un blocked it temporary
I read the bleeding instructions and it says to raise the vehicle and move the steering left to right while the filling or adding fluids and check for bubbles .....
