2003 CLK 500 Hydro-Lock
Hello a few months ago while driving to work at night I drove through some standing water from a flooded river. While going through, the engine hydro-locked and caused a bent piston rod. I was able to drain the engine change the oil after wards the engine started up ( With of coarse the engine pinging ) and drive it around the block. Now a month later the engine wont start w/ a fully charged battery interior electronics are working Air Vents/Stereo/Dash Board Light/and interior lighting. But when I turn the key there is no belt movement, just a click. I'm wondering if the engine is causing the starter to stop because of the bent piston rod and not engage, or would the starter become damaged for being submerged in water even tho is started after 2 days of the initial incident a while back, Could there also be some other electrical issues? Or would the spark plugs need to be changed because of the water? I have a spare engine to do a swap w/ but i'm looking to see other peoples opinions on what also could be the issue. Thank you and have a great day!
Once you figure that out, and it still does not start, I could be several things. The starter may have gotten water in it and has rusted/corroded while sitting for a month, the same water messed up some electronics or electrical connection, or the engine is damaged enough that it is binding up after a month with some residual water in it. You can always pull your plugs and then put a socket on your crank pulley bolt and see how freely the engine turns. If it turns freely, then it probably is not that. But start with your battery and report back.
