how do i get rid of the rear fog light ?
My car has this weird thing where the passenger side tail light lights up brighter than the driver. How can i turn this off ?
Either you don't turn it on...haha...or you check your bulbs. You must have some bulb errors somewhere. Are you running LEDs or weird bulbs in there?
You could also remove the tail light and take a look at all the contacts and all that stuff.
I changed the bulbs now twice . I am using regular bulbs . and still the passenger side is brighter . Rudeney yes it is very bright . Even when i turn on the rear fog lights the driver side is not as bright . If it is a sam issue is it fixable ?
Not sure if I remember correctly, but aren't the fog bulbs in the same place but just a double filament bulbs? If that's the case it sounds like a control module as Rodney says.
