Clock stuck at 12:23
2008 CLK350 without navigation:
Everytime I try to set the clock and then hit the reset button, the clock spins back to around 10:30 then just goes back to 12:23.
The clock setting also just goes back to 12:23pm.
The time never advances past 12:23pm.
MBworld Guru
"and then hit the reset button" - do you mean the stalk, to reset the trip odometer? So does the clock setting stay at the proper time until you press the reset stalk?
When I hit the reset trip odometer button to set the time, the clock starts to move to set the time as it normally should. Once the clock starts to reverse direction back to 12:23, the digital display also resets back to 12:23pm.
MBworld Guru
Oh, I see, I forgot you have to press the reset stalk to confirm - I was used to having COMAND where it sets automatically, but I see you don;t have NAV. You might try resetting the cluster by pulling the fuse (#42).
