Please remove key and beeping
Old May 7, 2004 | 12:50 PM
TheRok's Avatar
W209
I just picked up my CLK500 and I love it. I only have one issue. When I turn off the car and open the door a message appears on the center cluster and says “KEY” “Please remove key” and it is followed with a beeping that will not shut off until I close the door.
How do I turn off that beeping?
The car is a 2004 with keyless go, parktronic and COMMAND.
Any help would be great.
Old May 7, 2004 | 12:53 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Unfortunately, that's something you can't turn off. I know of a person who actually traded the car back in because of that warning beep.
Old May 8, 2004 | 10:25 AM
freakinfreak's Avatar
2009 BMW 750i, 2008 Toyota Prius
Hit the top left button on your steering wheel. That will turn it off for that very moment. I wish there was a permanent solution. It drives me nuts too.
Old May 8, 2004 | 03:25 PM
Regime|Life's Avatar
That's absolutely ridiculous!
Old May 8, 2004 | 03:36 PM
mbtech208's Avatar
My thoughts exactly.
Old May 18, 2004 | 05:21 PM
Stefan's Avatar
C43AMG
Keyless Go
Ordering Keyless Go would be one Solution,then you don't have to put the Key into the Lock in the first place....
I know that's no "after buy" solution.... Sry
Old May 18, 2004 | 05:29 PM
samwzhang's Avatar
2004 CLK 320 Coupe
Re: Keyless Go
He has keyless go.
Old May 18, 2004 | 06:07 PM
tntmcj's Avatar
only amg
remove key
some more great input from stefan, you obviously do not know benzes. otherwise you would know that only appears in cars with keyless go, you sure you own a benz?
Old May 18, 2004 | 07:36 PM
Re: remove key
Of course he does! He crashed his limited edition SLK230 AMG!
Old May 19, 2004 | 08:10 AM
Nebraska99's Avatar
I dont have keyless go and my 500 does that.
Old May 20, 2004 | 04:57 PM
poloblinky's Avatar
Mercedes ML 500
all you have to do is hit the reset button (R buttton) on your dash, by the instrument cluster,and the beeping will stop. That message is to keep you from leaving your key laying inside the car. Since with Keyless Go, the key does not have to be in the dash, a lot of people left their keys inside and they would lock their key inside.
Old May 20, 2004 | 06:40 PM
TheRok's Avatar
W209
The car will not let me lock the key inside. If i leave the key on my seat and close door the locks will not go. I have the same configuration with the trunk. I really like the keyless go but the beeping can be a pain.
Old May 20, 2004 | 10:34 PM
shaady's Avatar
Yea, but the logic is flawed.
Keyless Go (SmartKey?) should be smart enough to NOT allow you to lock the car with the key in it, thus "alerting" the owner that the key is not in their possession.
Incessant beeping should be reserved for the "low-tech" keys
...and who drives around with the key "laying inside the car". I suppose if it fell out your pocket.
Old May 20, 2004 | 10:56 PM
RJC's Avatar
RJC
Various
The feature helps prevent you from leaving the key behind when you don't lock the car...as if you did it would be extremely easy for someone to drive away with your car. Some insurance companies will not pay a claim upon recovery if they find you left the keys in the car and it was stolen.
