HELLLPPPPPP!!!! w209
Old Dec 30, 2017 | 06:56 AM
Matthewj2's Avatar
04 w209
no start no lights nothing work out key in won't turn at all put a battery jump box no power nothing any ideas??????!
went to start car as I turned to start everything completely turned off ????
Old Dec 30, 2017 | 09:40 AM
Anker's Avatar
2009 CLK 350
Start by putting in a new battery and go from there. If the battery is shorted or completely depleted the jump box will not help at all.
Old Dec 30, 2017 | 11:32 AM
Matthewj2's Avatar
04 w209
my bad didn't use a jumper box was connected with cables from tow truck and no door lights nothing alarm didn't work windows didn't adjust when opened door
Old Dec 30, 2017 | 12:48 PM
Reanimation's Avatar
270 cdi w209
New Battery Job done
Old Dec 30, 2017 | 01:34 PM
Matthewj2's Avatar
04 w209
no, but wouldn't you get at least illumination from a door light or dome light if another car is hooked up to jump ???
Old Dec 31, 2017 | 12:40 AM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
If the battery is shorted, you may not get any power to the car circuits even if it is connected to another battery. It depends on the severity of the short. Perhaps you should get a volt meter and check the voltage of the battery. If it reads 12+ volts your problem could be elsewhere, but not necessarily as a battery reading could be load sensitive in the case of a defective/shorted battery.
You can also disconnect the + side of your battery and see if you at least get instrument and dome lighting with a jumper battery (car or jump-start battery) connected.
If there are still no instrument or dome lights, the problem is likely NOT your battery. I would then look at the power line from the battery to the rest of the car.
my 2 and 1/2 cents worth of opinion......
Old Dec 31, 2017 | 09:13 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The large lead-acid batteries used by MBZ are prone to plate warping. When that happens, the battery often shorts out internally and you won;t be able to jump start it. To test this, disconnect the suspect battery and then try to jump start. If that works, then it's the battery.
Old Dec 31, 2017 | 09:59 AM
Matthewj2's Avatar
04 w209
Fixeeddddddddd!!!
I had tried to look at the San module took everything apart everything was good
come to find out my ground terminal was corroded threw the rubber jacket inches into the cable
found out with a mistakenly numb into the cable which powered the car to move my windows back in place
oh the relief !!!!!!
Thanks everyone one for the advise much appreciated
Old Jan 9, 2018 | 02:49 PM
270 cdi w209
Originally Posted by Matthewj2
Fixeeddddddddd!!!
Well done mate Panic over
