My 2006 Mercedes 350 convertible is separated at the seam above the rear window can t
Old Jan 15, 2018 | 01:15 PM
Deskramp1's Avatar
2006 Mercedes clk 350
My soft top is in excellent condition but the seam has separated just above the rear window. Can this be repaired? Thanks
Old Jan 15, 2018 | 11:19 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
This is a common problem as these canvas tops age. Mine did this, and I tried to glue it from the outside. I was somewhat successful in that it held and kept water out, but it looked ugly. To do a proper repair, you need to peel the canvas back to where you can access the seam and then repair it from underneath, preferably with a combination of adhesive and stitching. I actually ended up replacing my entire canvas as it was getting to be worn and faded. I did it myself, but that is probably beyond most people's capabilities (it was almost beyond mine!). Search the forum for my posts about the seam repair and the canvas replacement.
