Everything in drivers door dead
Everything in the drivers side door is dead. I'm assuming it is likely a ground (or lack of) issue. Checked all the fuses related to the systems in that door.
Questions:
1) Is there a master ground wire from the door to the body? if so where does it show up on the body side?
2) I've been trying to remove the door panel.. There are several videos on this out there, but for some reason this door seems to be different than what i see out there. I pop the tabs out of the perimeter of the door and remove the screw under the door handle, but it looks like there is another screw under the faux wood trimplate....is there actually one there? what am i doing wrong?
Questions:
Also that while the power mirrors work on the passenger side they also are dead on the driver side. Do you know if the mirrors also work off the DCM?
I found a used DCM to replace this one once I can figure out how to get the door panel off..lol
