Drained the transmission
The fluid I got from the dealership is red. The stuff I got is 236.14, and that is apparently the correct fluid.
Did MB factory use a different fluid than what is now recommended?
Any thoughts?
I have pulled dozens of transmission dip sticks and the fluid is either red or black (burnt).
Not very red
MY2007 CLK550 Transmission Fluid at 40K miles (right sample)
MK2010 ML350 Transmission Fluid at 118K miles
The indie here told me that he drains the oil from the pan first and then shift gears in d-r-n-p to completely flush it. Also he added some 236.11 oil (half a liter, always used 236.10 before) Should I go for a full flush with 236.14 since I have no error codes but shifting hesitations? I have done the oil change twice as the you guys always mention with original filter. Car is little more than 90K miles.
So whatever is in the lines and cooler is what is left.
I am about to fill it up with new fluid.
How much should I put in to start with? The whole 9 liters? I haven't got my I-carsoft yet, it's on the slow boat from China, so I am going to just get everything full of oil and wait to warm it up to do the final run up and level setting proceedure.
Now that I have the proper gear to do this proceedure It's a snap. I hacked a garden sprayer and installed a regulator on it. Drilled a hole and installed a tube fitting in the top of the sprayer.
Just fill with tranny fluid and pressureze to about 5 psi and it's a snap to fill. Got the adapter for the transmission pan at Amazon.ca. for like 12 bucks I think.
My car has esy access to the torque converter plug, so doing this every 40k will be easy.
Should I be running it in neutal or drive or park?
And should I be checking the level with the engine running, and in what gear?
The printed instructions seem to be a poor German to English translation
https://mbworld.org/forums/attachmen...sion-fluid.pdf
P0750 -- Transmission shift Solenoid A
P1909 -- Transmission Temp sensor open or shorted
P0995 -- Transmission fluid pressure sensor switch F high
P0746 -- Transmission pressure control solenoid
Probably because my tranny have never been touched.... ever. and with 205,000mi on it maybe MB considers this a lifetime.
Anyway, I want to attempt doing a fluid change but I'm confused as to which tranny I have (722.6 or 722.9). A VIN lookup WDBTK56F87F207791 tells me its a 722.906. Looking for a good DIY video.
Rudeney posed the WIS for the 722.6 on another thread. http://benzbits.com/722_6/FluidFilterChange.pdf . Is there a 722.9 WIS floating around?
It only goes up to 6 because after that it goes to D and 7th gear.
These transmissions need a fluid change every 39k miles so it's amazing how it lasted until 205k without destroying itself.
The fluid change procedure is more complicated compared to the 722.6 5-speed but there are very good youtube tutorials on how to do it.
Another question: just looked at autohausz and they sell three different brand kits: Meyle, Febi, and more expensive Vaico. Which brand would you pick?
... I seem to have a real issue every time I touch liquids, I can't seem to get the seals right. After doing the change I now have a leak!! Grrr. It looks like its at the front center edge where its slightly angled, probably not perfectly on there. I used the Febi Bilstein kit from Autohausaz. Did anyone else notice that the new rubber seal didn't exactly fit tight onto the edge of the pan? Maybe when I put it on it moved a little. Going to have to take a look tonight. Sux.
BTW.. for those going to try doing this. 1: To get the fluid in I just bought and cut a cheap 25' tube from the Lowes, drilled a small hole in the 5qt container, held the hose in the container wrapped with cloth while putting pressure into the container from my air compressor. Worked great. #2 instead of IR temp on the case I had a FLIR camera that worked good (only problem is it started to give higher false temps once the muffler got hot and started throwing off heat.
The IR thermometer works better because you can pinpoint an exact spot on the pan and not get false readings from the exhaust. And as for filling, I think I'd have spent a little extra money and bought a cheap hand-operated fluid pump at Harbor Freight. I invested in the Assenmacher pump because even on the first DIY, I still saved money over having an indy do the change. And now that I've used it many more times, it has definitely paid for itself.
Since the gasket overhangs over the lip I'm really hoping I can just take that bracket off then pull on it a little without having to drain and take the pan off.
