Ignition Coil plug replacement help
I replaced the coil and the spark plug (actually changed all the spark plugs). A few days later the problem reoccurred. Have gotten P0305, P0300, and P0355 error codes.
I have put tension on the wiring/plug for #5 by twisting the cable before putting the connector plug onto the coil. It has run that way for a couple weeks.
I want to replace the connector plug/wiring but can not find the part to do it. There are repair kits for other cars but not MB. I have the plastic connector itself (new) but it does not have the wires.
Is the part (ignition connector/plug and wiring (pigtail) not available for this car? Does anyone know of a source to get the connector with wires or just the wires with the female connector. I can put it together myself if needed. Any help much appreciated.
