Center console lid stuck
Granddaughter tried to open the lid by pushing both side buttons-
Now I cant open the top with either side button or pull up the entire center section to get to the lower storage area.
HELP
the only thing I found on another on another site thread follows; I have big diameter fingers so after looking again at the videos and the thread about small fingers,
I guess I will need to try screwdrivers or something to depress the back tabs while it is still installed:::: then the front lever and side buttons.""It happens frequently with my wife. It's difficult for me to explain the procedure but it's fairly easy once you've done it.
In the crack below the top lid, there's a release mechanism that you can reach with your fingers to release, if your fingers aren't too big.
After that, you'll probably find that one of the hinge pins is out of its socket so you'll have to press the pin in with a small screwdriver or something while you line it up with the hole."""
The dual hinge is a really neat feature but it’s asking for trouble now that the cars are getting older!
Being a convertible, does the centre console have a remote locking function too? Or is it simply the glovebox?
Will try some different things today to try to get the lid off/open.
2003 W209 CLK500 -
Center console glove box / storage compartment -
For some unknown reason a lady tried to open the
center console / armrest lid straight back -
This action caused the lower black storage bin to
lift up about .75" and become stuck / wedged tight -
I mean tight as I have used some pressure (ie. force)
to try and push it back in -
As well as the entire lid / armrest coming off -
In doing a search I found this thread regarding the lid
but was un-able to find any info regarding the raised stuck
storage bin and how to re-install correctly -
If any forum members have experienced this situation
and were able to get the black storage bin back to its original
position please share or provide a link -
Thank-You
D.B.
Well I got the black box back in today
and will try to attach the armrest later
in the week -
Does anyone know if it is possible to
purchase just the armrest new or does
it come as part of the complete center console -
Looking for black -
Thank-You
D.B.
https://www.mercedespartsdelivered.c...str=2096804939
That is now a correct statement -
I went to the dealership today and
ordered the last black armrest that
was available from Germany -
I was told that it may take up to 3 weeks
to arrive -
Thank-You
D.B.
How is the center armrest lock removed -
I removed the top cover for the lock mechanism
but that is as far as I got -
The one video from Benzworld makes no sense to me -
Still waiting for the new armrest to arrive from The Fatherland
and I just learned today that the lock needs to be changed over
to the new armrest -
Thank-You
D.B.
2003 W209 CLK500 -
Thank-You
D.B.
If you get a replacement you can literally break out the old one as its all plastic.
That should allow you to get the cover off and then follow the pdf above and/or find the good instructional vid on youtube.
How one is stuck up is weird as all the happens to make it go down is a plastic spud getting pushed down very front middle.
