central armrest storage
Old Apr 8, 2018 | 05:04 AM
peckchic's Avatar
clk 200
CLK 200, 2004.
Whilst opening the hinged box, somehow I have lifted the whole tray by about 3cm, and now it won't sit back down at all. The main hinged box won't open in its new raised position, nor will the side-hinged upper tray open.
All suggestions welcome.
Old Apr 8, 2018 | 08:54 AM
dbldpr's Avatar
Veteran: Navy
Wow never saw that happen before. It has to have something caught on latches.
Old Apr 8, 2018 | 03:46 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That just looks like the armrest has been raised. Can you pull up on the front handle, and then lower it back into place?
Old Apr 11, 2018 | 04:45 AM
peckchic's Avatar
clk 200
Armrest storage box stuck... CLK 200K
Thanks both, I've already pulled, pushed and fiddled with the lid and lever latch quite a bit but its jammed solid.
I was hoping there would be a "magic catch" somewhere which would spring everything open.
But perhaps there isn't, so any ideas appreciated.
Old Apr 14, 2018 | 03:55 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
Can you open it MORE?
Old Apr 15, 2018 | 09:43 AM
peckchic's Avatar
clk 200
Thanks Eddie,
No, it won't go up (although I've managed to tap it down a bit). It's still stuck shut.
I've tried using the key which although it turns, doesn't change anything. It feels as though the front catch isn't "catching" anything, nor are the side ones.
Beginning to hope i haven't left any edibles in there!
Old Apr 16, 2018 | 12:54 AM
xsever's Avatar
2012 C300 4MATIC Sport
Originally Posted by peckchic
Thanks Eddie,
Check out these threads. They helped me fix a problem before.
https://mbworld.org/forums/c-class-w...opped-off.html
https://mbworld.org/forums/clk-class...oor-stuck.html
