Manually OPEN CLK COnvertible
Current Codes: B1928-Limit Switch Interlocked of soft top compartment cover remains in the switched condition, B1953-Limit switch interlocked of soft top fails to switch, and B1950-limit switch Catch Position of soft top lock fails to switch. I'd like to cycle the top to a fully open position to see if switches reset at best, at worse I need to know how to open the top to get to the switches for testing/replacement.
My question is...after 1)releasing the pump pressure, 2)turning the lock-out knobs on the rear cylinders (drivers and passenger sides), 3)pushing the hinge stops forward (x2) with the trunk open, 4)releasing the front latch by the windshield, and lastly 5)putting the pull straps through the hinges is there another step/release to actually lift the glass portion of the top first or do I simply muscle the rear cover (after closing the trunk) up and back and then the glass will lift up afterwards?
Thanks for the help and the wealth of info on this site.
http://benzbits.com/w209/soft_top/ManualClose.wmv
You will need both pull straps or something similar. A step stool/exercise block/cinder block (don't fall/use at own risk) will also be handy for added leverage when lifting/unseating the rear cover. I didn't use it originally, but after the fact I realized it would make it easier for shorter people.
BTW, code B1928 "Limit Switch interlocked remains in switched position" relates to micro-switch S84/13 on the driver's side strut. Another forum mentioned this code but I don't think the connection was made to this switch. I thank Dean over at BNZ Automotive in Sunbury, OH for help on running this to ground. If you live near his shop...he is excellent.
Also...1) Can someone tell me how much hydraulic fluid they have in their reservoir when the top is completely up and all hinges are latched? Mine is Full (at the Max level) and I believe it is suppose to only be 1/2 full when the top is in the top-up position.
2) Any pointers on the last step of closing the cover? In my experience with German cars, they don't like to be forced. I am reluctant to "force it". Thanks, and thanks for your patience.
