Window problem in the 230 clk 2001
Old May 18, 2018 | 12:13 PM
sport7's Avatar
Clk 230 k
Date 18/5/2018
Hi I have a few problems with my CLK 230 2001 , in the mornings when I start the car up sometimes an alarm bell comes on and gives one or two beeps , the windows fail to open and the roof cannot be operated , after driving for twenty odd minutes the alarm sounds again and gives off 13 to 14 beeps and if I push the window switches the window operate normally as does the roof . What may be causing this intermittent problem?
My battery quite often will have discharged during the night and the car requires a jump start. Would this be causing the problem
Any Ideas how to solve it please would be gratefully welcome
. Austin
Old May 26, 2018 | 05:33 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Austin.......no one has replied because your 2001 CLK230 cabriolet is a A208 class and you have posted in the A209 forum, together with both the power roof configurations and operation is quite different.
First of all, the power roof will only operate properly if the vehicle's system voltage is greater than 11 volts, so with a weak battery, until the alternator is able to restore the required system voltage, your power roof and windows will not operate properly. Solution: New battery
If the problem is not resolved with a new battery, there is a position switch that is not being properly actuated when your manually lock/unlock the roof's front bow to the windshield frame. When you unlock the front bow, actuation of this switch will tell the power roof controller to lower all the windows (if previously raised). Solution: readjustment of the switch's mounting screws so that the lever of the manual latch properly engages and/or releases the position switch.
Should you need more details or help, post here: https://mbworld.org/forums/clk-class-w208-5/
Old May 27, 2018 | 04:32 PM
sport7's Avatar
Clk 230 k
Clk 230 k window and roof problem .
Hi thank you for your help in solving my problem , it makes complete sense to me now and I appreciate your help.
Kind regards Austin
