3rd brake lamp: was yours dead or intermittent?
Old Jun 11, 2018 | 09:47 AM
Fathom39's Avatar
CLK 550
I get the message every now and then. I have stood at the back of the car while a helper mashes the brake pedal and sometimes it lights while other times it doesn't. Mine is not cracked. I don't know the history of trunk slams by POs. My situation seems like a bad connection. Do connections go bad in the assembly or the wiring leading up to it? What were your symptoms?
Old Jun 11, 2018 | 02:58 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Mine did this and so I removed it and separated the lens,expecting to find some broken wiring or bad solders. I found nothing. I thoroughly tested each LED and all wiring, put it back together (using silicone sealant to reattach the lens) and all was well. Note that the bracket should not be over-tightened. It just needs to be torqued enough to hold the light in place. Otherwise, it can put stress on the assembly and cause failures.
Old Jun 13, 2018 | 07:52 AM
TechSuperstar's Avatar
15' CLS400
Replaced mine.. I'm pretty sure many of us on here have had to replace it. Easy job.
Old Jun 15, 2018 | 09:16 AM
abqhudson's Avatar
2014 e350
The sensor on mine is intermittant. Light works.
Old Jun 15, 2018 | 08:11 PM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
+1. I've had the intermittent 3rd Brake light error and I replaced it with a new one. Problem solved.
Old Jun 17, 2018 | 11:35 AM
sailorben's Avatar
CLK W209
Both my CLKs have been fine with the 3rd brake light. Don’t wish to jinx myself however.. it would drive me mad, knowing it looked crap. I do see a few Benzes on the road with failing clusters though.
