Clk 320 cdi 2009 Click on Key Turn & Noise from rear
Old Jun 14, 2018 | 02:26 PM
ProudMercOwner's Avatar
mercedes clk 320 cdi
HELP ! Car has been in a garage for last 2 years and on trying the key, there is a click from the front (starter does not turn) and a whirring/humming noise from the back which lasts about 30 seconds. Battery is ok, and was disconnected throughout the 2 years. It has fuel, and has hardly been driven. Any ideas ? Thanks in advance
Old Jun 14, 2018 | 03:43 PM
Anker's Avatar
2009 CLK 350
Humming noise is fuel pump. Do the instrument lights dim when you hear the click. If they do, your battery is dead, the terminals loose, or the ground connection bad. If no dimming your starter is bad.
Old Jun 14, 2018 | 04:05 PM
Hi Anker. Thanks for responding. I have just tried starting it. The instrument lights remain on brightly when I turn the key, and the starter sounds like its turning by a very small fraction aswell.
Old Jun 14, 2018 | 09:21 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Forget whether lights are bright or not. CHeck the battery voltage. It needs to be 12.6v at rest, no less than 11v when cranking. If it's low, you need a new battery. Sitting (even disconnected) for 2 years without periodic charging will likely kill it.
Old Jul 1, 2018 | 06:32 AM
Just to close off this thread, the problem was due to the battery.
Old Jul 1, 2018 | 01:35 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Glad it's fixed, and thanks for the follow-up!
