soft top wont open, keyfob does not lower windows,
Good day folks. I have a 2008 CLK350, and just purchased about week ago. The former owner said that he had the softop operate once but it stop . we both are aware of the switch located in the trunk which is activated by the partition. Dont think that is the problem as I have tried to close that with a prop to trick it and the close partition message does not appear on the dash. Here is what is happening :
When I pull the switch to open the softop nothing happens. Windows don't go down and top does not move.
The roll bars are down in the back.
When I point the keyfob at the doors from the outside to roll down the windows they don't go down.
Can this be a Fuse? a relay?
thanks for any suggestions.
MBworld Guru
If the trunk partition is not properly closed, then you will get a message on the MFD (instrument cluster's multi-function display). Since you get no message, you have another problem. Do you hear the hydraulic pump running when you activate the switch? If not, it could be a bad pump or fuse. There are scan tools (no generic OBDII code readers) that can pull codes from the soft top module and give you more information.
As for not being able to open the windows or top via the fob pointed at the door handle, that is probably a bad IR sensor. It's a common problem. Once you get your sfot top operational, you'll want to invest in a SmartTop module.
2008 CLK550, 2015 GLK350 4 Matic, 2017 GLE
I have a similar problem on my 2008 CLK550, regarding the operation feature of the key fob. The fob works perfectly on all features, except outside operation of windows and soft top. The top works perfectly using the inside controls. Any additional information on the IR Sensor and SmartTop module would be appreciated.
Is that hat an aftermarket item?
New to the site, I really enjoy all the great information and help from you veterans. Hopefully, I can help soon as well.
PT835
